i ignored this part of diffeq, and i'm a scientist - and this is engineering, so...
does the wind cause a significant difference in the rate of change? where an outside component may cool so quickly that
internal stress, or differences across boundaries (ie piston/cylinder wall) would be a problem? i guess that is not relevant if the parts
are already stabilized at -40 and the wind blows on them...
I'm full-in on the mechanical brake - @jimvreeland - looks like internal routing? anything special at the ends to prevent water contamination?
yes, thats the only thing the wind might change...the rate at which something cools....but its the air temperature is what it is as far as inanimate objects are concerned. In the case of jim riding from his house to the beach...Im quite certain the brakes would be at ambient temp by the time he got there.
im willing to bet sram gave you the bb7s because either they know the guides cant hack it in low temps, or they legit dont know/didnt test it enough
Why even take a chance in the middle of Alaska....this is what the term "fail safe" was meant for. Ok plan on this part breaking...will we be fucked? no? ok good, use this then. Di2 on Jims bike...I would say the same thing...Why take any chances.
