FastFreddy
Got my replacement DK24, much better than the first one but I'm still not too impressed with Charvel's QC.
I had to put a small shim under the neck to angle it and stop the saddles from bottoming out. Action out of the box was .110 low E with the saddle bottomed out!, .09 high E with about .012 relief and it still had a ton of fret buzz from about 10th fret up to the 24th fret. After shimming the neck, leveling the frets, recrowning and polishing them I got it down to .065 low E, .045 high E, .006 relief and the saddles now have some adjustment range up and down. Just a tiny hint of buzz now here and there so not perfect but WAY better than stock.
The stock output jack makes a ton of noise/looses connection if you just barely move the cable at all so I picked up a Pure Tone jack to replace it with that I'll solder in tomorrow to hopefully fix that. I also replaced the stock plastic nut with a Earvana compensated nut and got the action at the first fret down to about half of what it was out of the box. Oiled and cleaned the fretboard, put on a new set of 10-52 strings strecthed, tuned and intonated. A lot of work for a BRAND NEW $1K guitar if you ask me, but all in all it was a fun little 4 hour project. Now I just need to start practicing and playing more....a whole lot more!
