Going Long and Hard.
As rad as theses races are, it's all the behind the scene/race within a race stuff that I find totally fascinating.
Do you think that incorporating materials that retain some measure of elasticity (at that temp) into the harness could reduce the chance of breakage?
Sooo ... NOT carbon fiber. 🙂
Peanut M&Ms, trail mix, fruit snacks. I had Skratch in my bottles up to Checkpoint 1 and then refilled with GuBrew (which upsets my stomach as well) Also had a RedBull at Checkpoint 1.
not trying to criticize or anything, but my biggest issue with ultra endurance racing is properly fueling myself and ive gone through the same nausea you have too. Sugary stuff is really easy to eat and packs calories and energy, but for such prolonged efforts, it becomes too much, and i find myself needing to go after more complex things like carbs and protein. after a while the sugar ceases to go down well in either solid or liquid form.
Now i try to knock back a bottle of perpetuem during a race because i know it has longer lasting calories. ive learned that for ultra long efforts (20+ hours) real food (pizza, pasta, drinkable soup, cheeseburgers) gives me better energy which my stomach can handle when the sugary race food starts making me nauseous.
I feel like the flip and break was like a 1 in 1000 fluke thing that happened. I wouldn't necessarily look at it as a mistake.
Shortly after you race was over, I was actually gonna ask do you think you could have finished if you slept instead of trying to catch up?
From what you have learned from this, how is Alaska going to be different?
Alaska will be flat with no elevation. And shorter. In Alaska there's the possibility of it being brutally cold and of getting several feet of snow in one shot. Each of these races has it's own set of challenges so I'll just have to see what happens. If the trail is fast I have an opportunity to do well, maybe even win. Will be interesting to see how the racers in the other distances will ride the first 130-miles. Someone like JayP may attack the course and try to set the record for the 130 as it's new for this year and he's only going to McGrath. Or, maybe he'll sit in and expect someone racing the 130 to pull so he only has to attack the second half of the 350?
One of my biggest hurdles is finding food that doesn't freeze. During normal training rides I eat Bonk Breaker bars and drink Skratch but bars freeze almost immediately. This round was a case of not eating because my stomach was off, I only ate 1 sandwich bag size of M&Ms in 20+ hours. I ate 6 times that during Tuscobia last year. I should've put a MetRX bar in my drop bag at Checkpoint#1, that would've helped I think. For Alaska I have no drop bags or checkpoints, the whole race is self-supported. Should be interesting.
ive heard keeping snacks in the pogies helps them not freeze
how bout halves of simple sandwiches like pb&j? maybe keep some stuff rotating inside a layer of clothing?
I do have pockets inside my shell. I was using them for my bottles. I had little packs of fruit snacks inside my pogies and they still froze solid. I'd just empty the bag into my mouth and let them melt as I went along. At -40 or so I doubt that trick will work. I also rode with the vents on my pogies open so my hands wouldn't sweat. And I took the insulation out around the bar.
hmm ok, and by inside a layer i just meant like tucked inside your bibs or whatever you got
chemical warmers stuffed in your foodstash?
line your stash with a piece of an emergency blanket?
have you scoped out this joint?
Is there any rule that say's you can't bake pizzas while on the move?
I'd need a trailer of some sort to carry a couple pizzas. Think one of those sleeves they put them in will keep them from freezing?
Image thief.
Awesome adventure Jim!
2 things that worked for me mentally and physically in Alaska were Endurolyte tablets in my water and beef jerky in my trail food.
The Endurolytes kept the water from freezing as easily and never bothered my stomach and I really looked forward to the jerky as opposed to the sugary trail food.
i may try a couple of these....wonder if i can get the water content low enough
to remain chewable?? will try it at 0F to see how it goes.
http://www.hellawella.com/9-meatless-jerky-recipes-vegetarian-you
Jim, do you do spicy (picante)?
Pat good idea. The challenge will be adding a protein, fat and sugar source to provide sufficient calories. And even the proteins will freeze at those temps, regardless of water content. Have to think about what could be added to remain pliable
