Air Compresor
DonBito
Crafstman
Model 919.167342
33Gal. 6.0HP MAX. DEV. HP
11.9CFM 150PSI MAX PRESS.
Similar to this one...http://www.sears.com/craftsman-33-g...0916473000P?prdNo=10&blockNo=10&blockType=G10
Two were tossed out at my job cause they fell off a storage rack and one got pretty banged up. I dugged them out and took home to fix. Got to put one together with all the undamaged parts and donor parts from an old lawnmower i had laying arround and need to sell it to make room in my garage.
This thing looks good, It works perfect and it doesnt leak.
$150.00 if picking it up.
$200.00 delivered anywhere no more than 1hr drive from me.
This is the other one i just rescued. Its missing some of the plastic covers and the handle is bent upwards. 2nd and 3rd pic is from a broken union that it will be replaced before sale. I installed the parts of the other one and holds pressure and works perfect!
I will let it go for $125.00
Hey DonBito
i've got a porter cable pancake that doesn't build pressure - if you like to tinker, you are welcome to it....not sure if it is a valve or ring.....
Fido
Kirt gave me his compressor it doesnt build pressure. I tried fixing it and I thought it was the manifold but the problem is the valve itself.
Another bump...
They are both still available.
and also, those that have sent me pm's, i did reply to them. I hope you got them.
Last bump!
If you are local, Morris co. or Lower Sussex co., and can pick this up at my house by this weekend, i will let them go for cheap! I REALLY need the cash and the space in my garage by this weekend. :cry:
100.00 each!!! This is first come first served!! send me a PM with your number and ill text you my address.
Located in Hopatcong NJ.
bump. If I didn't have one I would buy one.
Calling all home mechanics. This would be a perfect addition to your tools. Air tools make the job so much easier.
thanks for the bump dude! 🙂
and yes, they are still available!
100.00 bucks firm!
and first come first served gets their pick!!
and they both work!
p.s. @ Ferret...I replied to your pm
