The mechanics of the bike are not designed for that currently.
You basically have an assist-motor. It either gives something, or nothing. That's the state today. If it gives nothing, it simply acts as if the battery is dead. It is a primitive system here. You push the pedal, motor goes on, +1 or +2 or +3 depending on what level you have it on.
You'd need a really complex system to attain the erg mode you're aiming for. With Zwift, erg mode means that you WILL produce 200 watts on your own, like it or not. With the RES (Recovery Erg System) the mode would be different. You would want to maintain a power of 200w or less. So 20w is ok, as is 50, 100, all the way to 200. So like Coyote says, you now need to add a clutch and feedback system that adjusts based on how much power you're putting out.
Ok so get yourself in a situation where you have it set to 150w and you're riding at RV. 150w and that 50# bike is going to go uphill at like...maybe 1? You'll be so frustrated you'll throw the bike. So ok, drawing board again. I think you then need to go back to the bike putting out X watts, period. So your ride will be 200w plus whatever you put out. Otherwise you'll stall and fall over. So now you're 200w base plus whatever you do. The motor needs to measure total wattage plus motor wattage to get rider wattage. And it needs to then adjust to be able ensure you don't go over your target wattage while making sure the bike maintains some level of total output to ensure it moves forward and/or up. But then, again, we;re back at going DH at RV with the motor still pushing the bike forward. Hold on to your hats!
Or, you put the bike in turbo mode and just watch your HR and make sure you're keeping it in target.
I threw a lot of shit on the proverbial wall there, but I think the takeaway is that it's far more complex than the motors that exist today and the target market is extraordinarily small.
