Karate Monkey
Is there an app to generate more excuses?
Basically skipped any sustained workouts in March -
Vacation didn't help - when my original plans got the kibosh, I didn't recover.
And so goes the "bounce"
I'm going the opposite of @Karate Monkey with my home projects.
Here are a bunch of race clocks - 3'x1' - they are used at marathons.
Note they are two sided..
The segments of the digits are high-contrast neon yellow??? There are no "lights" -
the segments get flipped by a coil that is energized in a certain direction (review your magnetism from 6th grade.)
Cool eh
The clock with the missing minutes has a problem on the logic board - it was built in the mid '80s
when all the good music came out! The designer worked at Bell Labs. High concentration of Deadheads.
The logic is 'hard wired' - so there isn't anything to reprogram.
The guts look like...
The lack of flexibility is bothering me - so I've decided to replace the boards with a microprocessor.
Maybe add some internet-of-things connectivity, and spy on the people that come near the clock.
I mean, "send offers which match their interests."
Don't want to fry the coils with bad programming,
so i whipped up an LED display for proof of concept.
Yup - major geek action here. The microprocessor is an Arfuino Uno, simple and cheap.
Ignoring everything other than the display:
The first position is what is showing on the clock.
The fourth position s what I want to display next.
The second position is(are) the segments which need to be turned "off" to go from current to next
The third position is(are) the segments which need to be turned "on" to go from current to next
in an LED - it is just on or off - with the race clock - the change is from off->on and on->off are two different actions.
Why?
Cause the first thing you thought was, just go with "on" for all the ones that are supposed to be "on" and
"off" for all those that need to be turned "off" - or simply, do something to all seven segments, then worries
about transitions are moot.
That's true. But since sustainability is a buzzword now - and these clocks are battery powered,
each flip has a cost (12v x 120mA x 25ms.) When I simulated an hour of clock time counting seconds,
the number of flips was reduced by ~60% using this logic. (energizing a coil costs the same whether is flips something or not)
Flipping the segments also has a failure rate - more so with the horizontal ones since they deal with gravity.
Think of a 3 ->4. if the top segment doesn't flip "off" (haha) the 4 will look like a 9.
In the 10s of seconds or 10s of minutes would be out of bounds -
in the seconds it isn't a big deal - cause 5 is coming! and it needs the top segment - but in the minutes, it is going to be
5 minutes ahead for the whole minute. (you wouldn't want to be 5 minutes behind pace at the 5k mark)
More fun with clocks coming...
I know a couple of those guys. Maybe even one of the ones who designed it.
Go watch the flip-board in Newark Penn. They finished the refurbishment 7(?) years ago. Didn't they pull the one that was in New York? Didn't see it the last time through Penn.
