silvervwbeetle
For sale is my specialized fuse comp 27.5 plus MTN bike size large. Bike is in excellent condition with very little use as it was my second bike. Still has the original tires on it with little signs of wear. I mostly used this bike in the snow and cruising the neighborhood with my daughter. Bike has upgraded PRO carbon handlebars and SRAM GX crankset. The rest of the bike is stock. $1200
Technical Specifications
FRAMESET
FRAME
Specialized M4 Aluminum w/ Smooth Welds, tapered head tube and seat tube, forged post-mount 160mm disc, 148mm thru-axle dropout, alloy replaceable derailleur hanger
COCKPIT
HANDLEBARS
Stout Riser, double-butted alloy, 9-degree backsweep, 5-degree upsweep, 15mm rise, 750mm width, 31.8mm
SADDLE
Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
GRIPS
Specialized Sip Grip, half-waffle, S/M: regular thickness, L/XL: XL thickness
SEATPOST
TransX dropper, 30.9mm, S: 120mm, M/XXL: 150mm Travel
STEM
Specialized, 3D-forged alloy, 4-bolt, 7-degree rise
SEAT BINDER
Alloy, bolt-type, 34.9mm
SUSPENSION
FORK
RockShox Recon RL, Solo Air, Boost™, 51mm offset, 120mm of travel
BRAKES
FRONT BRAKE
SRAM Level, hydraulic disc, 200/180mm
REAR BRAKE
SRAM Level, hydraulic disc, 180/160mm
DRIVETRAIN
SHIFT LEVERS
SRAM NX, 11-speed
REAR DERAILLEUR
SRAM NX, 11-speed
CASSETTE
SRAM PG-1130, 11-speed, 11-42t
CRANKSET
Stout Pro, direct-mount
BOTTOM BRACKET
PF30 BB, 73mm shell
CHAINRINGS
Steel, 28T
CHAIN
KMC X11, 11-speed w/ Missing Link™
WHEELS & TIRES
RIMS
Stout Trail SL 27.5, 38mm internal width, tubeless ready, disc-specific
FRONT HUB
Specialized, sealed cartridge bearings, 15x110mm thru-axle, 24h
FRONT TIRE
Purgatory, GRID casing, GRIPTON® compound, 2Bliss Ready, 27.5 x 3.0"
REAR HUB
Specialized, sealed cartridge bearings, 12x148mm thru-axle, 28h
SPOKES
Stainless, 14g
INNER TUBES
Presta, 40mm valve
REAR TIRE
FRAMESET
FRAME
COCKPIT
HANDLEBARS
SADDLE
GRIPS
SEATPOST
STEM
SEAT BINDER
SUSPENSION
FORK
BRAKES
FRONT BRAKE
REAR BRAKE
DRIVETRAIN
SHIFT LEVERS
SRAM NX, 11-speed
REAR DERAILLEUR
SRAM NX, 11-speed
CASSETTE
CRANKSET
BOTTOM BRACKET
PF30 BB, 73mm shell
CHAINRINGS
Steel, 28T
CHAIN
WHEELS & TIRES
RIMS
FRONT HUB
FRONT TIRE
REAR HUB
SPOKES
Stainless, 14g
INNER TUBES
Presta, 40mm valve
REAR TIRE
