One of my outdoor coach light fixtures stopped working recently. The circuit has four coach lights (two at the front door, two at the driveway entrance). The other three are working fine. I then remembered that my sprinkler guy moved a head last month in the area of the now non-operative coach light, and I got to thinking perhaps during his digging he accidentally cut through the underground wire. So I dug around this morning on search of the Romex. Sure enough I found the sheath was nicked immediately in the area where the old sprinkler head was. I was going to splice it but before I did I wanted to see if any voltage was getting to the Romex when the switch was on. Voltage tester didn’t pick up any voltage/current (though it did when I applied it to the switch and the Romex leading to the other driveway coachlight). The nick doesn’t appear to have cut the wires, but it’s possible they’ve got moisture. So my question is: should I expect to have voltage in the nicked Romex when power is on? Or would any compromise to the Romex’s integrity prevent current from flowing from the house? If former, then perhaps the problem is elsewhere in the line?
